477
Mar 17, 2024 5:00 pm
Cause : PG-F3 Setting Error comes when the entered encoder resolution (F1-01), maximum output frequency (E1-04), and motor pole number (E5-04), the calculation encoder signal frequency exceeded 50 kHz (with PG-F3 option).
- The encoder signal frequency is too high.
- Set F1-01 to the correct encoder resolution.
- Reduce the maximum output frequency of the drive in parameter E1-04 so the encoder signal frequency at maximum speed is lower than 50 kHz.
