928
Mar 16, 2024 12:06 pm
Cause : PG Disconnect (for Control Mode with PG) comes when detected when no PG pulses are received for a time longer than setting in F1-14.
- PG cable is disconnected. Reconnect the cable.
- PG cable wiring is wrong. Correct the wiring.
- PG encoder does not have enough power. Make sure the correct power supply is properly connected to the PG encoder.
- Brake is holding the PG. Ensure the brake releases properly.
