SvE fault code in yaskawa A1000 drive
Cause : Zero Servo Fault comes when position deviation during zero servo. Torque limit is set too low Set the torque limit to an appropriate value using parameters L7-01 to L7-04.
  1. Excessive load torque.
  2. Reduce the amount of load torque.
  3. Electrical signal interference along PG encoder wiring.
  4. Check the PG signal for electrical signal interference.
