yaskawa a1000 ol2 fault
"OL2" fault in Yaskawa A1000 drive indicates a "drive overload condition". This means the drive detects that its output current exceeds the rated capacity for a sustained period, leading to potential overheating or damage.
OL2 fault in YASKAWA A1000 drives indicates an overload condition. This means the motor is being subjected to a load that exceeds its rated capacity.
Potential Causes of A1000 OL2 Fault:
  • Mechanical Overload: The motor may be physically overloaded due to excessive external forces or resistance.
  • Incorrect Motor Parameters: The VFD might be programmed with incorrect motor parameters, leading to excessive current draw.
  • Faulty Motor: A mechanical issue within the motor, such as a bearing failure or winding problem, can cause excessive current.
  • External Short Circuit: A short circuit outside the VFD, such as in the motor cables or connections, can trigger an A1000 OL2 fault.
  • Overheating: Overheating of the motor or VFD can lead to reduced current capacity and cause an A1000 OL2 fault.
  • VFD Settings: Incorrect VFD settings, such as excessive acceleration or deceleration rates, can cause excessive current.
  1. Visual Inspection: Check for any visible signs of damage, overheating, or loose connections on the motor, cables, and VFD.
  2. Verify Motor Parameters: Ensure that the VFD is programmed with the correct motor parameters.
  3. Check for External Short Circuits: Inspect the motor cables and connections for any signs of damage or short circuits.
  4. Measure Motor Current: Use a clamp meter to measure the motor's actual current. Compare it to the rated current.
  5. Check for Overheating: Feel the motor and VFD for excessive heat.
  6. Review VFD Settings: Ensure that the VFD's acceleration, deceleration, and other settings are appropriate for the application.
  7. Check for VFD Component Failures: If the above steps don't resolve the issue, there might be a faulty component within the VFD itself.
  8. Consider Motor Replacement: If the motor is found to be faulty, it may need to be replaced.
