How do you reset the fault on Yaskawa drive?
To reset the drive for faults indicated by a red LED on display (on, not flashing), check fault code if fault is programmable then check parameter and reset fault, correct the problem and do one of the following: From the control panel, press RESET Turn off the power for 5 minutes.
If you are facing some error in Yaskawa drive then follow these steps to correct the fault:
Step 1
Identify the Fault: The first step is to determine what the fault is. AC drives often have built-in diagnostics that display error codes or messages. Check the display or control panel for any indication of a fault.
Step 2
Consult the Manual: Most AC drives come with a user manual that includes troubleshooting guides. Refer to the manual for specific error codes and their meanings. It may also provide steps to resolve common faults.
Step 3
Inspect Physical Connections: Ensure all cables, connections, and terminals are secure and undamaged. Loose or faulty connections can cause various issues with AC drives.
Step 4
Check Power Supply: Verify that the power supply to the AC drive is stable and within the specified voltage range. Fluctuations or interruptions in power can trigger faults.
Step 5
Review Parameters: AC drives have numerous parameters that can be configured for specific applications. Check the drive’s parameter settings to ensure they are appropriate for your system. Incorrect parameter settings can lead to faults.
Step 6
Monitor Motor Operation: If the fault is related to motor operation, observe the motor’s behavior. Listen for unusual noises, vibrations, or erratic movements. These could indicate problems with the motor or its control.
Step 7
Reset the Drive: Sometimes, simply power cycling the AC drive can clear minor faults. Turn off the drive, wait for a few seconds, and then turn it back on. Be sure to follow proper shutdown procedures to avoid damaging the drive or connected equipment.
Step 8
Perform Diagnostic Tests: Many AC drives have built-in diagnostic functions that can help pinpoint the source of a fault. Run diagnostic tests as recommended in the user manual to identify any issues.
Step 9
Inspect Cooling System: Overheating is a common cause of faults in AC drives. Check the drive’s cooling system, including fans and heatsinks, to ensure proper operation. Clean or replace any components that are clogged or damaged.
Step 10
Contact Technical Support: If you’re unable to resolve the fault using the above steps, contact the manufacturer’s technical support or consult with a qualified technician. They can provide additional assistance and may recommend further troubleshooting or repair steps.
Remember to always prioritize safety when working with AC drives and associated electrical equipment. If you’re not comfortable or experienced with troubleshooting electrical systems, it’s best to seek assistance from a professional technician.
Click2Electro
Get free chat support...
🟢 Online
