yaskawa ol2 fault
Cause: Drive Overload comes when the drive's output current exceeds its rated capacity for a sustained period, typically around 60 seconds.
yaskawa ol2 fault indicates drive overload condition. This means the output current exceeds the drive's rated capacity for 60 seconds. This can be due to several factors, including excessive load, incorrect motor wiring, or faulty components.
  • Reduce Load: Ensure the load is within the drive's rated capacity.
  • Verify Motor Wiring: Check for correct connections and proper insulation.
  • Inspect Components: Examine the motor, drive, and any intermediate devices for faults.
  • Adjust Parameters: Configure settings like V/f pattern and carrier frequency appropriately.
  • Check Electrical Supply: Ensure stable and balanced voltage supply.
  • Configure for Motor Type: Set parameters suitable for the specific motor type used.
