Yaskawa E7, G7, GA800 & GA500 Drive
489
Mar 19, 2024 5:59 am
Cause : External Fault (Input Terminal S3) comes when external fault at multi-function input terminal S3. An external device has tripped an alarm function.
- Remove the cause of the external fault and reset the multi-function input value.
- Wiring is incorrect.
• Ensure the signal lines have been connected properly to the terminals assigned for external fault detection..
• Reconnect the signal line - Multi-function contact inputs are set incorrectly.
• Change the terminal settings.
