dFPS fault error code in yaskawa R1000 drive
Cause : Drive Model Mismatch comes when the drives used in the copy and write process are not the same model.
• The drive from which the parameters were copied is a different model.
• The drive to be written to is a different model.
  1. Verify the model number of the drive from which the parameters were copied and the model of the drive to which those parameters will be written.
  2. Make sure the two drives are the same model and have the same software version.
