End4 fault error code in yaskawa FP605 drive
Cause : Adjusted Slip Calculation Error comes when the Auto-Tuning results were not in the applicable parameter setting range.
  1. Make sure the input motor nameplate data is correct.
  2. Do Rotational Auto-Tuning again and correctly set the motor nameplate data.
  3. If you cannot uncouple the motor and load, do Stationary Auto- Tuning 2.
