oL2 fault code in yaskawa P1000 drive
Cause : Drive Overload comes when the load is too large or the drive itself is experiencing an overload condition. The acceleration/deceleration times or cycle times are too short.
Here's a step-by-step guide to troubleshoot and resolve the issue:
  1. Check Load Conditions: Assess the load connected to the drive. An excessive load or sudden changes in load can cause the drive to overload. Ensure that the load is within the rated capacity of the drive and that there are no mechanical issues causing undue strain.
  2. Verify Parameter Settings: Review the parameters in the Yaskawa P1000 drive to ensure they are configured correctly for your application. Check the current limits, torque limits, and any other relevant parameters. Adjust them if necessary to reduce the load on the drive.
  3. Inspect Mechanical Components: Examine the mechanical components connected to the drive, such as belts, pulleys, couplings, and gears. Look for signs of wear, misalignment, or binding that could increase the load on the drive.
  4. Monitor Drive Performance: Use monitoring tools provided by the drive to observe its performance during operation. Look for signs of excessive current draw, overheating, or erratic behavior that may indicate an overload condition.
  5. Check Ambient Conditions: Assess the ambient temperature and humidity levels in the environment where the drive is installed. High temperatures or humidity can exacerbate overload issues. Consider installing additional cooling equipment or relocating the drive to a more suitable environment if necessary.
  6. Inspect Power Supply: Check the power supply to the drive for any abnormalities, such as voltage fluctuations or inadequate power delivery. Ensure that the power supply meets the specifications required by the drive.
