Yaskawa Z1000, L1000A, L1000E & V1000 Drive
300
Mar 29, 2024 6:58 am
Cause : PM Rotor Position Estimation Error comes when an invalid value resulted from Initial Pole Search or Motor characteristics have changed.
- Parameters that control Initial Pole Search are set incorrectly (set up may be incomplete).
- Parameters for the motor encoder are set to the wrong values (set up may be incomplete).
- Repeat the setup process.
- Perform Stationary Auto-Tuning or Initial Pole Search Auto-Tuning.
- Brake was released during Initial Pole Search or during power loss.
- Check the brake sequence.
- The brake must remain applied during Initial Pole Search and whenever the power supply is interrupted.
- Initial Pole Search cannot be performed on the motor being used.
- Use a PG option card that is compatible with both the drive and an absolute encoder
