EF0 fault code in yaskawa L1000E drive
Cause : Option Card External Fault comes when an external fault condition is present. An external fault was received from the PLC and F6-03 is set to a value other than 3.
1. Remove the cause of the external fault.
2. Remove the external fault input from the PLC.
Problem with the PLC program Check the PLC program and correct problems.
