Yaskawa Z1000, L1000A, L1000E & V1000 Drive
250
Mar 28, 2024 5:07 am
Cause : External Fault (input terminal S3) comes when external fault at multi-function input terminal S3. When an external device tripped an alarm function or wiring is incorrect or multi-function contact input setting is incorrect.
- Remove the cause of the external fault and reset the fault.
- Properly connect the signal lines to the terminals assigned for external fault detection.
- Reconnect the signal line.
- Change the terminal settings.
