PGo fault code in yaskawa L1000A drive
Cause : PG Disconnect (for any control modes using a PG option card) comes when no PG pulses are received for longer than the time set to F1-14.
  1. PG cable is disconnected- reconnect the cable.
  2. PG cable wiring is wrong- correct the wiring.
  3. PG has no power- check the power line to the PG encoder.
  4. PG encoder brake is clamped shut- ensure the motor brake releases properly.
