Yaskawa Z1000, L1000A, L1000E & V1000 Drive
211
Mar 29, 2024 7:51 am
Cause : PG Disconnect (for any control modes using a PG option card) comes when no PG pulses are received for longer than the time set to F1-14.
- PG cable is disconnected- reconnect the cable.
- PG cable wiring is wrong- correct the wiring.
- PG has no power- check the power line to the PG encoder.
- PG encoder brake is clamped shut- ensure the motor brake releases properly.
