Millicoulomb to Coulomb (mC to C) Converter
Quickly convert Millicoulombs (mC) to Coulombs (C). Includes the conversion formula, a quick reference table, and the definition of electrical charge units.
Millicoulomb to Coulomb Converter
Millicoulomb to Coulomb Formula
A Millicoulomb (mC) is a submultiple of the SI unit of electric charge, the Coulomb (C). The prefix “milli” signifies one-thousandth ($10^{-3}$). Converting between these units is straightforward:
1 Millicoulomb (mC) = 0.001 Coulombs (C)
To convert mC to C: Divide by 1,000
To convert C to mC: Multiply by 1,000
Conversion Quick Reference Table
This table provides a quick way to find common conversions from Millicoulombs to Coulombs.
Millicoulombs (mC)Coulombs (C)
1 mC0.001 C
10 mC0.01 C
100 mC0.1 C
1,000 mC1 C
5,000 mC5 C
What is a Millicoulomb?
A Millicoulomb (mC) is equal to one-thousandth of a Coulomb. In practical electronics, Millicoulombs are often used to describe the charge stored in larger electrolytic capacitors or the total charge transferred by small batteries over time.
What is a Coulomb?
The Coulomb (C) is the standard SI unit of electric charge. It is defined as the amount of charge transported by a constant current of one ampere in one second (1C = 1A × 1s). It represents a significant amount of charge; for example, a single Coulomb is approximately $6.242 \times 10^{18}$ times the charge of an electron.
Common Usage Examples:
  • Capacitors: A 1000µF capacitor charged to 10V stores exactly 10 Millicoulombs of charge.
  • Batteries: Smartphone battery capacities are usually listed in mAh (milliamp-hours). 1 mAh is equal to 3.6 Coulombs or 3,600 Millicoulombs.
  • Static Electricity: A typical static shock you feel from a doorknob usually transfers only a few microcoulombs, which is much less than a single Millicoulomb.
