nE.dOH message in KEB COMBIVERT F5 Drive indicates no Error Motor Overheat. This means the motor temperature has dropped back to an acceptable level and the overheat fault can be reset.
Motor temperature has dropped back to acceptable levels.
The motor overheat sensor is reset, and the Error Motor Overheat fault can be reset.
