40: ERROR line frequency fault in KEB COMBIVERT R6 Drive
40: ERROR line frequency fault in KEB COMBIVERT R6 Drive indicates the main line frequency is out of tolerance. This means the incoming AC supply frequency is unstable or exceeds the allowable operational window.
Main Line Frequency out of tolerance.
Verify the stability and frequency parameters of the input supply.
