31: ERROR External Fault fault in KEB COMBIVERT R6 Drive
31: ERROR External Fault fault in KEB COMBIVERT R6 Drive indicates an externally triggered error. This means a peripheral device or a manual jumper signaled the drive to trip, often used to identify high regenerative currents or voltage sags.
External Fault. The R6 has been programmed to trigger this error for assistance in identifying high regenerative/supply current and line voltage sag (refer to CP.19 settings and section 6.2 for troubleshooting).
The error can be triggered by an external device through one of the digital inputs, or manually by setting a temporary jumper across X2A.15-X2A.17. Refer to CP.21 – CP.28 for use with the fault log.
