9: ERROR drive overheat fault in KEB COMBIVERT R6 Drive indicates an over-temperature condition at the commutation choke. This means the temperature sensor detected excessive heat, likely due to poor ventilation, and the delay timer has expired.
Over temperature commutation choke; temperature sensing on the commutation choke indicates the choke is too hot and the overheat delay timer has run out.
Allow the commutation choke to cool down. Check ventilation and structural choke layout.
