A010 alarm in WEG CFW900 Drive indicates Rectifier Overtemperature. This means the input rectifier modules are running unusually hot, warning of potential cooling issues or overload.
- High ambient temperature around the inverter (> 50 °C) and high output current.
- Blocked or defective cooling fan.
- Inverter heatsink is too dirty, preventing proper cooling airflow.
Note: It can be disabled by changing the IGBT Overtemp. setting to fault only in parameter C7.5.1.
Clean any dust from heatsink fins. Verify fan operation and clear any blockages. Improve surrounding cabinet ventilation. Check settings in parameter C7.5.1.
