F011 fault in WEG CFW900 Drive indicates Rectifier Overtemperature. This means the input rectifier modules have exceeded their safe thermal limits and the drive has tripped to prevent hardware damage.
- High ambient temperature around the inverter (> 50 °C) and high output current.
- Blocked or defective cooling fan.
- Inverter heatsink is too dirty, preventing proper cooling airflow.
Verify fan operation and clean heatsink fins. Improve room/enclosure ventilation as needed to reduce surrounding ambient temperature.
