A0140 fault in WEG CFW500 Drive
A0140 alarm in WEG CFW500 Drive indicates a Profibus DP Module Access Error. This means the internal connection between the drive and the Profibus option card is failing.
  • The Profibus DP module is not seated properly in the slot.
  • Hardware errors due to improper handling or installation of the accessory module.
Verify Profibus module mounting in slot. Replace communication module if handling errors damaged the pins.
