A0148 alarm in WEG CFW500 Drive indicates an Ethernet Interface Access Error. This means the drive’s main control board cannot correctly communicate with the attached Ethernet module.
- Ethernet module is not properly connected to the product.
- The drive firmware version does not support the module.
- Hardware errors caused by improper handling or installation of the accessory.
Ensure the Ethernet module is physically secure and correctly seated. Verify that the drive’s firmware version is compatible with the module. Replace the card if the hardware is damaged.
