A0152 alarm in WEG CFW701 Drive indicates a High Internal Air Temperature. This means the ambient air inside the drive’s casing is dangerously warm, warning of ventilation issues.
- High surrounding air temperature (>50 °C (122 °F)) and high output current.
- Defective internal cooling fan (if existent).
- High temperature (> 45 ºC) inside the cabinet.
Note: It can be disabled by setting parameter P0353 = 1 or 3.
Ensure enclosure or cabinet ventilation fan is operating correctly. Clear blockages from airflow grilles. Check parameter P0353.
