F0151 fault in WEG CFW701 Drive
F0151 fault in WEG CFW701 Drive indicates a FLASH Memory Module Fault. This means the removable memory card is unreadable, corrupted, or improperly inserted.
  • Defective FLASH memory module.
  • Incorrect or loose physical connection of the FLASH memory module.
Verify the physical slot connection of the FLASH memory card. Replace the memory module if card is damaged.
