A0168 alarm in WEG CFW701 Drive indicates the Speed Error is too High. This means the actual motor speed is deviating significantly from the commanded speed, usually because the drive is limiting torque.
- Inverter in torque current limitation.
Ensure the motor is not overloaded or stalled. Check torque limits in P0360.
