F0169 fault in WEG CFW701 Drive
F0169 fault in WEG CFW701 Drive indicates the Speed Error is too High. This means the actual motor speed deviated significantly from the commanded speed for too long, indicating a stalled or bound motor.
  • Inverter in torque current limitation for too long.
Ensure the motor is not locked or mechanically bound. Check limits set in P0360 and P0361.
