A020 alarm in WEG CFW900 Drive indicates a 24Vdc Power Supply Undervoltage. This means the external 24V control power supply has dropped below the minimum operational threshold.
- Voltage of the 24 Vdc power supply that feeds the control is below the minimum permitted value of 22.8 Vdc.
Check the incoming 24 Vdc supply wiring and voltage levels. Ensure the external power source is rated correctly.
