A0211 fault in WEG CFW701 Drive
A0211 alarm in WEG CFW701 Drive indicates the Drive is in Fire Mode. This means the specific digital input assigned to activate emergency fire mode has been triggered.
  • The digital input programmed for activating the Fire Mode is active.
Check the status of the digital input assigned to activate the Fire Mode. Confirm that external switch logic is correct and not stuck in the active state.
