A0210 fault in WEG CFW701 Drive
A0210 alarm in WEG CFW701 Drive indicates the Drive is in Bypass Mode. This means the system has been switched to bypass the inverter and run the motor directly from the mains power.
  • The digital input programmed for activating the Bypass mode is active.
Check digital input settings and external wiring assigned to Bypass mode activation.
