A0758 fault in WEG CFW701 Drive
A0758 alarm in WEG CFW701 Drive indicates the Engineering Unit is not programmed for Hz or rpm. This means the display unit parameter for motor speed needs to be explicitly configured.
  • Parameter P0516 is not programmed in 13 (Hz) or 3 (rpm).
Configure parameter P0516 to option 13 (Hz) or 3 (rpm).
