A0760 alarm in WEG CFW701 Drive indicates a Low Level of the Main PID Process Variable. This means the feedback sensor reading has dropped below the minimum programmed process threshold.
- Parameter P1030 is programmed in 1, and the Main PID controller feedback value is remaining below the value programmed in P1031 for the time programmed in P1032.
Check feedback loop lines. Verify parameters P1031 (threshold) and P1032 (delay).
