F0761 fault in WEG CFW701 Drive
F0761 fault in WEG CFW701 Drive indicates a Low Level of the Main PID Process Variable. This means the drive switched off the motor because the process feedback sensor remained below the safe threshold for too long.
  • Parameter P1030 is programmed in 2, and the Main PID controller feedback value is remaining below the value programmed in P1031 for the time programmed in P1032.
Verify loop line pressure/flow. Check values set in parameters P1031 and P1032.
