A0762 alarm in WEG CFW701 Drive indicates a High Level of the Main PID Process Variable. This means the feedback sensor reading has exceeded the maximum programmed process threshold.
- Parameter P1030 is programmed in 1, and the Main PID controller feedback value is remaining above the value programmed in P1033 for the time programmed in P1034.
Inspect process line for high limits. Verify values set in parameters P1033 and P1034.
