A0770 fault in WEG CFW701 Drive
A0770 alarm in WEG CFW701 Drive indicates Filter Maintenance is needed. This means the running hours of the system have exceeded the programmed threshold for filter replacement.
  • Parameter P1050 is programmed in 1, and the total motor operation time shown in P1052 is greater than the time programmed in P1051.
Perform preventive system filter replacement. Reset the elapsed timer if required.
