F0769 fault in WEG CFW701 Drive
F0769 fault in WEG CFW701 Drive indicates a Broken Belt Detected. This means the inverter detected a high-speed, low-torque condition for too long, tripping the drive to protect the system after a belt snap.
  • Parameter P1046 is programmed in 2, the motor is running faster than the speed programmed in P1047, and the motor torque is remaining below the torque value programmed in P1048 for the time programmed in P1049.
Check the mechanical coupling belt/pulley state. Verify the parameter configurations for P1046, P1047, P1048, and P1049.
