A0786 fault in WEG CFW500 Drive
A0786 alarm in WEG CFW500 Drive indicates a Low Level of the External PID Process Variable. This means the external PID feedback sensor reading has dropped below its minimum programmed threshold.
Parameter P1075 is programmed for 1, and the process variable of the external PID controller remained below the value programmed in P1076 for the duration set in P1077.
Verify the process feedback loops and verify configurations in parameters P1075, P1076, and P1077.
