A0788 fault in WEG CFW500 Drive
A0788 alarm in WEG CFW500 Drive indicates a High Level of the External PID Process Variable. This means the external PID feedback sensor reading has exceeded its maximum programmed threshold.
Parameter P1075 is programmed for 1, and the process variable of the external PID controller remained above the value programmed in P1078 for the duration set in P1079.
Verify process line sensors. Check parameter thresholds set in P1075, P1078, and P1079.
