A0786 alarm in WEG CFW701 Drive indicates a Low Level of the External PID 1 Process Variable. This means the external PID feedback sensor reading has dropped below its minimum programmed threshold.
- Parameter P1075 is programmed in 1, and the External PID controller 1 feedback value is remaining below the value programmed in P1076 for the time programmed in P1077.
Check the process feedback sensor and loop line. Verify configurations in parameters P1075, P1076, and P1077.
