F0787 fault in WEG CFW701 Drive indicates a Low Level of the External PID 1 Process Variable. This means the external PID feedback sensor remained below the safe threshold, triggering a system fault.
Parameter P1075 is programmed in 2 and the External PID controller 1 Feedback value is remaining below the value programmed in P1076 for the time programmed in P1077.
Check the physical process line and feedback loop sensors. Verify the parameter configurations for P1075, P1076, and P1077.
