A0796 alarm in WEG CFW701 Drive indicates a Low Level of the External PID 2 Process Variable. This means the second external PID feedback sensor reading has dropped below its minimum programmed threshold.
Parameter P1095 is programmed in 1 and the External PID controller 2 feedback value is remaining below the value programmed in P1096 for the time programmed in P1097.
Check the physical process line and feedback loop sensors. Verify the parameter configurations for P1095, P1096, and P1097.
