F0797 fault in WEG CFW701 Drive
F0797 fault in WEG CFW701 Drive indicates a Low Level of the External PID 2 Process Variable. This means the second external PID feedback sensor remained below the safe threshold, triggering a system fault.
Parameter P1095 is programmed in 2 and the External PID controller 2 feedback value is remaining below the value programmed in P1096 for the time programmed in P1097.
Check the physical process line and feedback loop sensors. Verify the parameter configurations for P1095, P1096, and P1097.
