A110 fault in WEG CFW900 Drive
A110 alarm in WEG CFW900 Drive indicates a High Motor Temperature. This means the motor’s PTC thermistor is warning that the motor is approaching its maximum safe operating temperature.
Alarm related to the PTC temperature sensor installed on the motor.
  • Load on the motor shaft is too high.
  • Load cycle is too short (high number of starts and stops per minute).
  • High ambient temperature around the motor.
  • Poor contact or short circuit (resistance < 100 Ω) on the wiring connected to the motor thermistor.
  • Motor thermistor not installed.
  • Motor shaft locked.
Note: The alarm can be disabled by setting C7.5.2. It is necessary to program Slot X analog input and output for PTC function.
Check mechanical load, motor bearings, and temperature. Secure thermistor wire terminal screws and verify resistance is not < 100 Ω.
