A128 alarm in WEG CFW900 Drive indicates a Serial Communication Timeout. This means the serial network link dropped out before new control data was received from the master.
It indicates that the CFW900 stopped receiving telegrams on the serial interface for a period longer than the setting programmed in C9.3.5.
- Check network installation, broken cable or fault/poor contact on the connections with the network, and grounding.
Note: Make sure the master always sends telegrams to the equipment within a period shorter than the setting in C9.3.5. It can be disabled by setting C9.3.5=0.0 s.
Check serial connections, shield grounding, and wiring. Adjust master polling times, or disable timeout by modifying C9.3.5.
