A133 fault in WEG CFW900 Drive
A133 alarm in WEG CFW900 Drive indicates No Power Supply on the CAN Interface. This means the required 24V external power supply is missing from the CAN network connector.
It actuates when the CAN interface is powered and lack of power supply to the interface is detected.
  • CAN interface without power supply between pins 1 and 5 of the connector.
  • Power cables switched or reversed.
  • Poor contact on the CAN interface cable or connector.
Note: Measure if there is voltage within the allowed range between pins 1 and 5 of the CAN interface connector.
Check external 24 Vdc supply is active and connected correctly to pins 1 and 5. Verify cable polarity.
