A1326 / F1327 fault in WEG CFW900 Drive
A1326 / F1327 Slot C temperature sensor 1 error fault in WEG CFW900 Drive
These codes indicate a Slot C Temperature Sensor 1 Error. This means the external sensor wire is broken or short-circuited.
  • Sensor 1 cable is broken.
  • Sensor 1 is short-circuited.
  • Sensor 1 is located in an extremely low temperature environment.
Check temperature sensor 1 cabling for open or short circuits. Verify that surrounding environmental temperatures are within system parameters.
