A1328 / F1329 fault in WEG CFW900 Drive
A1328 / F1329 Slot C sensor 1 high temp / overtemperature fault in WEG CFW900 Drive
These codes indicate a Slot C Sensor 1 High Temperature. This means the monitored external equipment has exceeded its safe thermal limits.
  • The monitored equipment is operating at high temperature.
  • Fault actuation level configuration error.
Verify equipment active operating temperature levels. Review parameter configurations for fault actuation thresholds.
