A1330 / F1331 Slot C temperature sensor 2 error fault in WEG CFW900 Drive
These codes indicate a Slot C Temperature Sensor 2 Error. This means the external sensor wire is broken or short-circuited.
- Sensor 2 cable is broken.
- Sensor 2 is short-circuited.
- Sensor 2 is located in an extremely low temperature environment.
Check temperature sensor 2 cabling for open or short circuits. Verify that surrounding environmental temperatures are within system parameters.
