A1332 / F1333 Slot C sensor 2 high temp / overtemperature fault in WEG CFW900 Drive
These codes indicate a Slot C Sensor 2 High Temperature. This means the monitored external equipment has exceeded its safe thermal limits.
- The monitored equipment is operating at high temperature.
- Fault actuation level configuration error.
Verify equipment active operating temperature levels. Review parameter configurations for fault actuation thresholds.
